Mine was never working. I disconnected everything. I have not yet checked inside the steering column. but most likely the suspect fault would be inside. My volts light flickers its not the battery, alternator, or the ignition coil. Some lame o mechanic problem pitched some wires while fixing the loose column. My key buzzer also doesn't work. Good luck on your find.
