Water leak...
85' 3.8 Limited
17
I have a water leak in my Regal and it has been leaking for the past 6 or 7 months. Every time I turn the car off, I hear a hissing sound, which is the water dripping on the exhaust on the rear, passenger side of the motor.. Is it the freeze plug (or glow plug) that is leaking???
Peter
1,175
74
48
MA
i suppose a freeze plug could be a possiblity but in many cases with manifolds the freezeplus will actually sit lower than where they could drip on the manifolds. could be a freezeplug on the backof the engine or in my case the engine that i pulled to put in my car had a heater hose valve that was leaking that dripped onto my exhaust. My 3.8 never did anything like that so i wouldnt have an answer of something that notoriously happens but the best bet is start exploring, not saying it would be easy to find though because i know how much of a mess the stock engine bays on these cars are
85' 3.8 Limited
17
Where is that valve located at??? I am pulling out the transmission and working on replacing that freeze plug in about 2 weeks or so. I might check that valve while I'm under there.
Peter
1,175
74
48
MA
well the 3.8 wont have the same exact thing imtalking about because i was referencing an olds engine but it would helpful to follow the two heater lines coming out from the firewall on the passenger side a look for leaks, drips, cracks whatever. It wouldnt be all that uncommon to find a leak in one of the old hoses
st1nger
23
sounds like you need to do a radiator pressure check put pressure check tool on your car in place of radiator cap; run car for 10 minites to open thermo stat then turn off motor pump up gage and coolant system leak will be exposed the more you pump the more pressure and air and water have no where to go except out of leak you should be able to find leak eaily since it should being spraying under presure had a pin hole one time, never could find the leak thermo stat would close and leak would go away .
did the pressure check, turned motor off started looking found it in about 2 min, it was a heater bypass hose took 2hr to replace hose but 2min to findlooked for weeks would never have found it
