Water leak
1979Calais
735
69
Maryland
My floor is rusted out on the passenger side and finally found where the water is coming in at, after spraying water around the windshield. Can someone tell me what to do in order to stop the water from coming in.
cant tell exactly from picture but if hole is small enough i would just silicone it.or if could you make some type of cap that would let the water run off . but try the silicone first its cheap and easy.
Thanks, I will try that. I was thinking that a piece was broken off and should replace the whole piece. I will use the silicone and see what happens by this weekend.
i looked at my monte carlo and it looks like yours is broke but just missing a tab that sticks up for the hood seal.you could replace it if it bothers you but i would at least seal it up for now and start looking for the heater box. but i would rather it look bad versus replacing a floor. good luck.
I already have to replace my floor. Look at my build thread and you will see how bad it rusted out my floor. I will be sealing it up this weekend, because I will have day then. I hate the winter!
