Well intake gasket is holding. Still has a leak on the rad. Either its a low level sensor or a aftermarket part. Has a rubber stopper with a hoseclamp just under the neck above the trans lines.
Brakes work great. But the front end bottoms out and smashes into the pavement under full lock up. So I take it new springs are in order as well as shocks. Seems like It rides higher on the passenger side. So hopefully a saggy spring.
Now onto performance holy crap this thing sucks!! My 79 Electra coupe with a buick 350 was twice the car. Fixed the vacuum leaks took it out and mashed it probably around 35 mph "speedometer is shot" and it took literally 10-15 seconds to kick down. Then all kinda cool exhaust sounds and not one dam bit of speed increase.
Haven't pulled the plugs.wires are cheap Napa jobs but don't look that bad. Cap and rotor look ok. Not sure if it would help at all. Carb has been run what looks like years without any air cleaner. But today it was 9 degrees and it took 4 pumps and half throttle to start fired instantly and kicked down to idle in 15 seconds with no problems. Doesn't seem like the carb or plugs are culprits. Now if them vac lines are not properly attached would it cause the dog like behavior? Does sound like sh*t at full throttle. Like its trying to get up and go but is falling flat on its face. Seriously a Yugo could smoke this P.O.S
350 crate maybe in order.
