In my search for an engine with high power density and low weight, I came across this little 600cc (36ci) 2 cylinder snowmobile engine from Ski-Doo. It puts out an astonishing 115-125 hp! It's a 2 stroke direct injection engine with a fuel cooled computer, and meets current EPA emissions regs too. The weight is low (maybe 100-120lbs?), and it redlines at 8100 RPM. It takes technology from the Evinrude E-TEC marine engines to make it all possible. Now this thing is useless in a G body, but think of the possibilities for fuel economy and acceleration in a lightweight car (Mini, Yugo, Geo Metro, Fiat 500, Trabant, etc). In a snowmobile it gets over 20mpg. In a small car weighing around 1200lbs with the right gearing it could top 35mpg city and run 12's in the 1/4. The only negative is that it is liquid cooled, so you would need a radiator, and it has a pull start so you would need to figure out how to adapt it to an electric start and a normal automotive alternator to make it work in a car. I figure it has a shaft style output, so maybe it could be mated to a Harley trike transmission ( they have reverse) through a custom primary with a built in starter and alternator.
Here's the PDF on it:http://corp.brp.com/NR/rdonlyres/3F...CB76F60B74/0/2007_01_31_ETEC_backgrounder.pdf
