what exhaust you running
ok...so wut does the x pipe do?
i see alot of people with that and ive been wondering for a minute...lol
The point of the X pipe is to provide equal back pressure in both exhaust pipes and it helps quite down the exhaust just a bit. I'm running an H-pipe where you just run a pipe directly between the two exhaust pipes. This can help with both fuel economy and performance as it gives the engine better exhaust breathing and flow.
the x-pipe also helps increase flow velocity which scavenges the exhaust and can actually help suck air in at the beginning of the intake stroke.
afterburner headers, pypes 2.5in w/X and street pro's.
Flowtech long tube 1 5/8" primaries and 3" collector reduced to 2 1/2" through a custom X-pipe by Muffler Masters in Kannapolis, NC and through THRUST mufflers dumped out before the rear axle
Wish I had a video camera to get a good sound clip (my cell phone sucks) but it sounds really good, loud but good!
Once the 403 gets in, I'll have a 2 1/2" set of straight back pipes w/ dynomax mufflers and an "H" pipe duping right before the axle.
Until then, I have a cat deleted stock exhaust.
Here's a vid, ignore the black splotch of paint,I have repainted the lower 1/4. Also, ignore the odd rattling towards the end of the vid, that was the flange from the cat still just hanging on the pipe. Since been removed.
Hooker 2451 1-5/8" headers with 3" collecters
Hooker 3" to 2.5" reducers
Pypes bolt in 2.5" kit w/ x-pipe
Street Pro Pypes mufflers
Absolutely love it. Only thing I'd like to change are the one pipe I needed to get from Autozone isn't stainless, the bulky clamps, and a different set of headers.
Stock 305 with duals and glasspacks, off the manifolds. And out the back. Stock x-member (both pipes run side by side until after the x-member, but still true duals).
http://www.youtube.com/watch?v=TME6JqzWR8s
wow didnt think i'd get this many response's but thanks good vids too well my ? is now ... i plan on getting longtubes hookers, an would it be better choice for X pipe or H pipe? an is the cost cheaper for one or the other, an 2 ? is is being dumped at the rear better then straight see a lot you guys have it dumped? thanks
An H-pipe works well but I believe it's mostly just in the lower end of the RPM band while an X-pipe helps make more power through the RPM range.
You'll also notice that an X-pipe will give the exhaust note a bit more of an "exotic" sound to it compared to an H-pipe.
The H-pipe is probably slightly cheaper and easier to install.
Dumping the exhaust at the rear as opposed to having tail pipes doesn't really affect the power. It's just easier and cheaper to do. However its also going to be louder since the exhaust is dumping out point at the ground and reflecting back up to the underside of the car.
On my car it was just easier to do the dumps because with the watts link and pro-touring rear sway bar, bending 3" exhaust pipe to clear all of that would be a nightmare.
If you do dumps, one thing that can help with the sound is to angle the outlets towards each other a little under the car.
to add to FE3XCLONE's post,
I found the dumps resinated at roughly 1400rpm in my car. It may be different with different motors, but this is the range which I found my sbc 350 to resinate the most.
Resinating makes the whole car vibrate, and pretty much anything around it. If you live in a quiet neighborhood, with many people using car alarms, people may get tired of you vibrating their houses and setting off alarms everywhere.
It may sound and feel cool, but it gets old eventialy :roll:
In my car, it was as simple as adding tailpipes to get rid of the resinance, and keep the throaty exhaust note.
If you plan on using dumps, you could also point them towards the sides of the car. If you plan on using tail pipes, there are a few options too...
1. there is the classic Monte -straight out the back- look
2. there is a GN -angled outward behind the rear wheels- look (like on my car)
3. and I think there is a -sideways behind the rear wheels- look as well.
option #3 is great for doing smokey burnouts, as the exhaust pushes the tire smoke outwards... seen here on my buddy's 69 Cutlass.
http://www.youtube.com/user/torinosport ... Xh29eF1fUU
anyways,
Hope that helps
No tailpipes definitely increase the amount of resonance, and the body acts as a megaphone of sorts, amplifying it. It does get old after a while, I cut part of the tailpipes of my TBI 350-equipped pickup some years ago, and after a few months had a new set of pipes put back on... I must be getting old :roll:
