Applications:
Will fit many GM vehicles equipped with an 8.5 inch 10 bolt c clip axles. Side gears are 30 Splines. Note that some axles from vehicles in the following list may have had 28 or 30 spline shafts. 30 spline axle shafts are typically found on 1997 and newer GM vehicles.
Typical applications from 1997 - up:
Models include:
C15/C1500 1/2 ton: 88-99
C1500/C2500 3/4 ton: 97-00
C25/C2500 3/4 ton: 97-00
Caprice: 89-96
Escalade: 99-00
Express Van 1500 1/2 ton: 96-03
Express Van 2500 3/4 ton: 96-98
G10 1/2 ton: 88-95
G15/G1500 1/2 ton: 88-95
G20/3/4 ton: 88-95
G25/G2500 3/4 ton:88-95
Impala: 88-96
K10/K1500 1/2 ton: 88-99
K15/K1500 1/2 ton: 88-99
K5 Blazer: 79-91
S10 Blazer/Pickup: 94-98
S15 Jimmy/Pickup: 94-00
Savana 1500 1/2 ton: 96-03
Savana 2500 3/4 ton: 96-98
Sonoma: 94-98
Suburban 1/2 ton: 98-00
Tahoe 1500 1/2 ton: 95-00
Yukon 1500 1/2 ton: 92-00
other full size GM vehicles
It was used in a lot of heavy vehicles so I'm guessing it is stout enough for stock usage. But a 455 may be over the line, especially if you plan on hot rodding it and/or beating it up. It differs from a clutch type posi in that it has a centrifical weight that as the slipping wheel speeds up, the weight flies out and then the posi engages. So in the snow my wheel would spin, then go "clunk!" as the posi kicked in. I'm thinking a worked 455 would split it open like a watermelon.
