What size slick will fit!?
chevyfan16 said:
I'm not thread jacking but do they make a slick for 14 inch rims?
yes
Yes you will need to get one for an import.
It's all going to come down to the backspacing on your rims if your not looking to modify the frame at all. With the 30x9's on my race cutlass there is about 1/4 inch between the slick and frame. Now on my 87 T Type Regal we have 28x10.5 for the Outlaw 10.5 but a frame notch kit was installed. Deffinatly opened up alot of room and is strong then before. Now you could sqweeze a bigger tire under there but with the with the backspacing you would have to get it would stick out past the quarter panel a little. I don't mind that look but some like them tucked up under. You man need to roll the lip of the quarter some to create clearance so it does not rub.
