x2 if it's a perimeter bolt cover. the trick is to put a 1/8in continuous bead down on the head and let it set for 5min. then put a thin layer on the cover (use your finger to "smear" it on, you should be able to actually see through it) and place the cover on the head. put the bolts in place but do not tighten them down for at least 15min (not even finger tight.) then torque them down properly. you'll need an in/lbs wrench.
i do this even with gaskets (especially cork) but i use a very thin layer on both sides instead of a 1/8in bead.
