What about rims that have been widened to 15x8? What tire would give factory sidewall but wider tire for the rear.
if they are 15X8 with 4" BS you can generally put up to a 275/60 without rubbing. For factory 26" height, 275/50.
Stock GN wheels get really close to the frame with 275/60's and will rub more with slightly wider 275/50's. It may only rub one side, but odds are pretty good there will be frame rub. Nitto 275's were smaller than MT or BFG's and maybe could get away without excessive rub, but any other 275's will likely rub.
1/4" spacer or aftermarket 15X8 4" BS GN wheels should work good with 275/60's. T-type wheel's have 1/4" less BS than the GN wheels and don't have a problem on the frame with 275's.
Don't ever disregard the importance of tire rotation. I bought a set of Dunlops for my truck and had them rotated faithfully and the tires lasted me 9 years! I would never have gotten 9 years and even tread wear if i didn't rotate the tires.
