Hi guys!
Thanks for the informations !!
So I have some news :
when I withdraw the drum, I still have a play in the rear right axle so It doesn't come from the drum. Maybe 2mm rotational play and 1 mm axial play even when the wheel is tightened. I have checked on youtube, and It seems normal to have a little play on axles with C-Clip. Do you confirm ??
I have just seen that the inside of the tire is worn, so I guess the inside of the tire already touches the fram !!
![](https://cdn-0.gbodyforum.com/proxy.php?image=https%3A%2F%2Fs15.postimg.cc%2F3ugv8dwvr%2F20180613_091822_Copier.jpg&hash=59f38a4443a471f79245ec69f0148769)
![](https://cdn-0.gbodyforum.com/proxy.php?image=https%3A%2F%2Fs15.postimg.cc%2Fptn9vot6f%2F20180613_091831_Copier.jpg&hash=f5eb35fc0bb34b57728a2a61b4c35917)
The problem is that I don't want to change the studs of my axles by longer ones. That's why I would prefer a bolt on adapter !
Why do you think it's to much 1" adapters without jacked up tail? because the wheel will be to much outside and the tire would be touching the vehicle body ?
![](https://cdn-0.gbodyforum.com/proxy.php?image=https%3A%2F%2Fs15.postimg.cc%2Fo1ub0ump3%2F20180613_095143_Copier.jpg&hash=e8430b6d77745e7728f1badc7fe24899)
On the photo it seems to have a lot of space between the tire and the body, no ?
For my problem of hubcentric :
I was think of putting a hubcentric plastic ring 69.7->72.4 on the right wheel and a 70.5->72.4 ring on the left wheel.
Then putting 72.4mm adapters, and then putting hubcentric rings that goes from 72.4 to 82.8 mm
Is it posible to do something like that ?
Thanks a lot !
Thanks a lot !
