Hello all, I have a 7.5" in my car and I'm wondering what's the right gear oil to use. The crappy Chilton book doesn't say and google doesn't yield anything. Just a good old stock GM 7.5" with a little aluminum tag reading "USE LIMITED SLIP DIFF LUBE ONLY". Before you ask, no, I do not have the RPO code list to determine if it is LSD, and I'm not exactly in a position to jack the entire rear end off the ground(parked on a hill, brakes don't work right, transmission is having some issues). Anyway, if y'all could let me know what I should use, that would be great
