Wheel lug fitment when changing from 7.5" to 8.5" rear axle
dgmeadows
190
600
Georgia
My 1979 Cutlass had a 7.5" rear axle. As part of drivetrain upgrade, I acquired an 8.5" rear axle from a 1984-5 Hurst Olds. The '79, 7.5 axle had 7/16" lugs, the newer 8.5" has metric lugs.
I ordered Year One 17" Olds SSII wheels with 7/16" lug nuts. It appears the 7/16" lugs from the 7.5" axle are not a direct swap into the 8.5" axle. The flanges on the 7/16" lugs are smaller than the recess in the 8.5" axle (i.e., the metric lugs have a larger flange.)
So, has anyone encountered this ? Does anyone have a part number or other reference for a 7/16" lug that will have the correct size flange to fit the 8.5" axle ?
Thanks for any insight.
I would contact YearOne and see what they offer in the correct metric size to fit those wheels with the 8.5.
Reactions: oldsmobile joe
Yep, that is an option. Year One does have nuts for both the 7/16" and metric applications. We just didn't want to have sae in front and metric in back.
You could change the rear studs to 7/16" but would have to either match the knurl on the factory studs or go to a larger size and drill the axle for them
My 9" came with 1/2" studs and I drilled my front rotors to install 1/2" ARP studs to not only increase strength but also so all the lug nuts were the same.
Looks like we will have to have sae front and metric rear lug nuts. We cannot find 7/16" studs with the same size head/knurl as the 12MM studs. Not too big a deal, Year One has the metric lug nuts in stock. I am using staggered size wheels, so won't be doing rotations front to rear. I will just have to remember the lug nuts are different.
Upgrade the front brake rotors to a year with metric lugs. Get a set of 20 metric lug nuts. Done.
