wheels
GbodyBeginner
23
Hi , I am new to the site and G body cars , I am making an engine swap to a 406 and want to run these tires on the rear Tire Compound: M5
Tire Overall Diameter: 26.1''
Average Roll Out/
Circumference: 82''
Tire Tread Width: 8.3''
Tire Section Width: 10.5''
Wheel Diameter: 15''
Spec Wheel Width: 8''
Tire Weight: 20.0 lbs
Suggested Tube
Part Number: 672-9553
Also want to use Weld Racing Pro Star rims on the rear what back spacing will I need or will the tire and rims even fit ? also want to run skinny's on the front , so again what back spacing is required ? Thank You !
From the specs this looks similar to a 295/50 tire? Ok if so I had them on my car with 15x8 cragars. The bs was 4.25, but I had to use a half inch spacer. So if youre buyin new wheels and have a choice of back spacing, I would go with a 15x8 wheel with around a 3.75 bs.
