Or find out what's really wrong with your motor. Low vacuum can be and usually is a sign of weak motor, assuming ( here I go again ) you have you have eliminated vacuum leaks, have your distributor installed correctly, and have your carb adjusted correctly ( idle mixture screws, throttle blade position, idle speed ). Bad / worn rings, burnt valves, worn valve guides, and too much cam timing can all attribute to low vacuum. Even altitude has an effect on an engines ability to produce vacuum. Ex.- I live in Houston, TX ( approx. 100ft above sea level ) but the same engine in Denver, CO ( approx. 6500f above sea level ) will not produce as much vacuum, without retuning. That's one reason the LOW ET / HIGH MPH records are all usually set at lower altitudes. Most records are set at Texas Motorplex ( Dallas ) and Royal Purple Raceway ( Houston ). You have heard of the Texas Mile. Ok, I checked and you live in Ohio, so this is probably not your problem, but it needed to be stated for others reading this in the future. I don't know the condition of your motor, but a leak down test should be in your future. Your cam specs ( I checked the Mutha Thumper line up ) do not warrant a vacuum pump. A vacuum pump is a band aid for your actual problem. Although it may help save your life! LOL I'm not knocking your motor, your decision, or your problem. This is just my .02 cents. Take it or leave it... I will not be offended, and I hope I did not offend you. I back up my statements with the demise of injectedcutty's dead motor, and the fact that your vacuum can did not help. I apologize if I offended you, or injectedcutty. Good luck. James-
