I was assuming the offset was that -6.4 in the one picture, but what that translates to I don't know.Do you know the backspace on those rims?
Luckily I am close to factory ride height minus some spring sag. I may go ahead and bite on these rims then. I knew there was an issue with some of the 15 inch rims fitting but I couldn't remember if the 4wd ones or the 2wd ones wouldn't fit.Any of the 16" S10 rims will fit with no spacers. You may (probably will) have rubbing on the front if your vehicle is lowered and still have stock upper balljoints, instead of longer ones.
4wd wheels will not fit. Backspacing is way too much. S10's had a total of three different wheel diameters. 14, 15, and 16". All 16" were 2wd only...Luckily I am close to factory ride height minus some spring sag. I may go ahead and bite on these rims then. I knew there was an issue with some of the 15 inch rims fitting but I couldn't remember if the 4wd ones or the 2wd ones wouldn't fit.
New front springs are on the list, but in the meantime I have coilover shocks helping things out in the front.4wd wheels will not fit. Backspacing is way too much. S10's had a total of three different wheel diameters. 14, 15, and 16". All 16" were 2wd only...
Edit- You say you have spring sag. If they are original springs, you probably have more sag than think. Center of the front wheel, from ground to fender lip, stock was around 27"+ a little.... if your around 26" or less, the tires may rub on the inner fender over larger bumps, dips, etc.
