I am going to get the CK reman 10 vane pump, supposed to give 295 psi. The last time I added boost valves and 13 vane pump, had it lying around, a .500"/.296" boost valve with Transgo high rev pump slide spring and pump rings to a 2004R pump, it didn't work so well. The reverse pressure was good, foward pressure was a dismal 180 to 190, sliding soft shifts. I never checked the clearance and there is better slide spring options. I used a .555" boost valve, brought it up 215 to 220 psi, nice firm shifts. I will be using the CK Billet servo and CK uses the. 555" boost valve in their pump and their shift kit is supposed to be the best. This trans should have the hardened sun shell. So I will do the billet foward drum and welded on shaft from CK. I may consider the input but should be under 550 ft/lbs, maybe slightly under 500 ft/lbs. I will know as soon as I pull clutches from the foward drum, the condition of the trans. A new hardened stator is another questionable part getting replaced.
