Which Transmission & Engine
Your Preference Transmission
  • TH200-4R
    Votes: 0 0.0%
  • TH350
    Votes: 0 0.0%
  • 700r4
    Votes: 0 0.0%
  • Total voters
Respected_Cutlass
Jun 5, 2009
69
84 Cutlass Supreme - Choosing between the 350 Olds and Chevy is impossible for me. I would love to keep an Olds heart in an Olds body but I hear Chevy creates more power and is probably easier to upgrade. I also understand it will be more work to do a Chevy transplant. To remove all the love for your choice, which motor is actually better, power & durability wise?
Onto the transmission, which one? THM 200-4R or TH350? I really don't know if I need/prefer an overdrive as I have never noticed anything different with driving the two (I didn't know what I was looking for). Can someone explain?
As I read, I see a lot of people don't like the 700r4, what does having a LOW first gear mean? I'm taking a guess here, better burn outs or increased 0-30mph? What is the disadvantage of a low first gear? My friend has an 88 GMC 1500, should I recommend a better transmission?
i hear the Olds motor will drop right in where the chevy will require a lot of changes with vacuum lines and stuff
If you have a TH350 now, to mount a 200r4, I understand that you'll have to mount a new cross member.
See this site for more info: http://crossmembers.com/g-body.htm
In terms of which motor to choose, rather than picking one based on a bunch of preconceived notions, why don't you see if you can get a reasonably-priced running example of either near you first? Neither makes more power than the other, per se.
Also, you didn't say what motor you have in there. If it's a 231 v6 the easiest swap would be a 350 Buick, and to get a Chevy or Olds in there, you'll have a lot of mving things about to do.
Relative to the other trans questions, the page here can answer them: http://www.bowtieoverdrives.com/index.shtml
And after reading more of it, that transmission is expensive. Definitely not gonna be my choice. Still though, would anyone use it?
They're nice transmission's but the only reason I would use it is if I were an old rich guy enthusiast who wanted to electronically paddle shift my restomod....or if I got an amazing deal.
I vote th350, a short tail will bolt right up with a universal transmission mount (the one with 3 holes in it). The gear ratios are also nicer for street driving. If you want an overdrive I'd splurge for the 2004r
Olds can make just as much power as a chevy. The Olds makes more torque everything being equal, which is great on the street. Unless you get a late model block with roller cam and modern fast burn style heads, why even consider the sbc? Parts cost a bit more for Olds, but not a ton more.
