I'm hoping someone can give me an opinion of what is wrong with my car. I have an 87 Monte Carlo SS with a 350 small block in it that is putting out white smoke from both sides of the exhaust. It has true dual exhaust so I'm hoping that its not a head gasket because I would think it would only smoke from one side. I highly doubt both gaskets would be blown. It is losing a little coolant every so often but it is not going into the crankcase. The oil looks clean and when I open the radiator cap the water is clear as well with no bubbles when I open the throttle a little bit. It does not overheat either. The water is obviously going out the exhaust because there are no leaks and I am wondering if it could be the intake manifold gasket or a crack in the manifold itself. It has an Edelbrock aluminum manifold on it and I dont know if they have a history of cracking. I bought one of those block tester kits and it passed so I am hoping to rule out the head gaskets. Any advice is appreciated. Thanks.
