So I took it to the shop to see what's causing vibration, and the flex plate is all torn up. The mechanic also noticed that the torque converter doesn't fit snugly onto the crankshaft - the hole is too big and it moves around, which is what he thinks ruined the flex plate. He asked me if it was the OEM engine and transmission, which it is - only 54k miles on it. He also tried a torque converter for an 85 cutlass with the same result. I have a 1987 Cutlass Supreme Brougham with a 307 V8 and there's a position for overdrive on the gear selector. Do I have the 200r4 transmission? Has anyone had a similar experience? Could the crankshaft be warped, or might the torque converter just need a bushing to fit snugly?
