Ignition problems normally only give the symptoms you descibe if the coil is starting to break down, a misfire a fault on the output dide would most likely occur at all engine speeds.
A clogged cat. wouldn't normally make the engine splutter either.
Your symptoms seem like fuel starvation rather than an ignition fault IMO,I would look at the carburettor first, maybe the secondaries aren't getting fuel, don't discount that the new fuel filter may be bad - it's not unknown.
