Doing a little more digging, the guy who did the diesel to gas conversion for some reason welded a washer to the kickdown cable slide by the carb, then bolted it solid to the throttle. So as soon as you touch the gas, the cable would slide start to slide out. This has been like this for years, the previous owner had no clue as to why it was done that way. The kickdown doesn't work at all now and I doubt it ever did. What kind of problems am I looking at inside the transmission?
