They will fit but if you have a small port intake it won't be worth putting them on the 350. You'll have major port matching problems. All Olds small blocks share identical exterior dimensions, and pretty much all parts interchange besides pistons, and the later intakes with the dinky square ports unless you use the heads that go with them which is no use on a 350.
