Will an L82 Dual Snorkle work on a 79 cutlass 305?
johnny79
192
2
DC
Hi all,
Anybody know if this will work on my car? I'm pretty much sold that an open element is not the way to go, so I'm going to buy another single-snorkel for my vehicle and fabricate one, or try this one, but for the price I don't want to get it wrong....
I know the L69 dual snorkel supposedly works, but any advice would be good. Any advice on the best way to get performance out of the air cleaner as well..
Thanks!
More info...
http://www.nastyz28.com/camaro/z28l82.html
It's the same carb....
1973 Z28 Engine - L82, 245hp
Block 3970010 4 bolt main, suffix codes: CLJ, CLK, CLL, CLM
Crankshaft 330550 Forged steel
Cylinder Head 330545 2.02/1.6" Valves, 76.18cc, tapered spark plug, screw in studs & guide plates
Cam 3896964 symbol: vertical diamond, GM part # 3896962
Intake 3997771 Has oil shield, EGR, Intake Runners Numbered
Carb (A/T) 7043212 Rochester Quadrajet 4BBL, Remote Automatic Choke, w/Automatic Trans
Carb (M/T) 7043213 Rochester Quadrajet 4BBL, Remote Automatic Choke, w/Manual Trans
Distributor 1112148 Single Point, Uniset contact, RFI shield, Vacuum, Lite Blue paint spot
RH Exhaust 3986330 Log type, 2.026" outlet
LH Exhaust 3989041 Log type, 2.026" outlet
Alternator: Delcotron 37 Amp, part # 1100934
Water Pump: 6263701
Cylinder heads have double pyramid casting mark.
Cam specs: Hydraulic, Lift: .450/.460 (intake/exhaust), Duration: 346/360 (i/e), with 1.5 rockers.
Engine block: Nearly every 350 you'll come across is casting # 3970010, some are 2 bolt, some are 4 bolt. Some are regular, some are 010, some are 010/020 (10-20 blocks). Check the suffix code to see what application the block is actually from. All Z28 blocks should be 4 bolt mains.
If you wanna do it the chap way. Just use a stock single snorkel. Then go to the junkyard and and find another one, then make a duel snorkel. You can get creative and look around at some different style snorkels from different cars.
