Will roller rockers fit under stock olds valve covers
KJ
n00b
Feb 22, 2009
2
I`m adding harland sharp roller rockers to olds 350 #7 heads. Will i need taller valve covers and will they fit under ac n pwr steering bracket?
I dont know what valve covers you are using, as there is different styles, but you might need tall ones or you might not. Depending on what kind you have, you might be able to get away with taller valve cover gaskets or cutting out the baffle in the valve cover. If those options do not work, you will probably need tall valve covers, but I do not know if they work with the a/c p/s bracket bracket. If you can take a pic of the valve covers, someone may be able to tell you what you will need to do.
As Dan noted, it depends. Frequently you can get by with removing the baffles inside the valve covers and stacking two gaskets. There is also a vendor selling valve cover spacers on the web.
