Will these fit
tc1959
3,963
1,975
Surprise AZ.
mysons80elcamino said:
Looking for some wheels i like these will they fit the 80 elky.
Also these have a 4.5 bs should I get 3.75 bs for front or not.
Thanks
http://www.summitracing.com/parts/crr-3305734p
Yes they will 4.5 is perfect I would go with the 8's all the way around. I am running 17 x 8's on all 4 With 4.5 B S No problems. No rubbing at all.
mysons80elcamino
Mar 27, 2012
84
Thanks
What would change if I went with 15x7 rather than 15x8. Just asking cause they are a lot cheaper. Lol
Fox80
563
4
16
Jamestown NY
Nothing will really change, the offset is measured on the backside, so you will lose the 1" of width from the hub outward. I've been looking into a lot of 15" wheels as well, to do the blazer brake swap, and I think you will find you have more options for tires on a 8" wide wheel. It depends on the look your going for a lower sidewall or more of a stock look, just something to keep in mind
mysons80elcamino
Mar 27, 2012
84
I want to keep it old school I like a thick tire like old hot rods, no low profiles for me..
Thanks I'm gonna order them !!!
Fox80
563
4
16
Jamestown NY
That is kind of what I look for as well, before you buy the wheels look into tires, a lot of online places tell you the recommended wheel you will be looking for something in the 60-65 ratio size depending on the width to keep the stock look
