I am looking at dong my next brake upgrade, 1 car got a blazer brake setup installed here recently that I used brembo rotors and stainless brake lines on. the other car, my 86 442 was about to get a ls1 brake upgrade done to stock spindles so I already had the calipers and abutments sitting in the shop for the last few years. I found another set of blazer spindles in the local salvage yard yesterday so I started looking into using the ls1 brakes on those instead. Well after reading a bunch of threads it seems that the ls1 brakes do not work easily with the blazer spindles BUT C5 brakes work great. I then read that the calipers on C5s and ls1 setups are very similar and are interchangeable. So what I want to do is use my existing ls1 calipers with a C5 rotor on the blazer spindle. From what I read the ls1 caliper actually has larger pistons and more bite but they may not be as strong with heavy track use which I don’t really see me needing. Also it means that I can swap the C5 caliper onto the ls1 abutments with no issues in the future which is a heck of allot cheaper than having to get the abutments for the C5 setup. as far as brackets go I have a drawing that gives me all of the info for the C5 abutments to be bolted to the spindle and from what I am reading the ls1 abutment spacing is slightly off, I plan to take that into account when I fab the brackets. I operate CAD for a living and my employer has a fab shop with materials on hand so the brackets will cost me nothing. if this can work the only thing I am going to be investing money into is rotors, pads and stainless brake lines. am I missing something that is preventing this from working? Thanks in advance for any help!
