my grandfather used stabil, but he said is was a waste of money. I think seafoam is a better product. He would either fill the tank up or drain it to keep the rusting to a minimum. He also put the car on stands and keep the tires off the ground so as not to flat spot them. Automatic transmissions are gonna leak if u leave fluid in them and the seals will dry out as well. Not much can be done about that, cause they werent designed to sit for long periods of time, unlike manual trans which are virtually leak free in most cases. As for rodents, keep rodent traps around the car and inside to catch them asap. My cat keeps my garage rodent free, but the best defense is keeping it inside. I have heard of using sulfur around the perimeter of the car, which is suppose to keep out just about any critter...(old country trick used for keeping snakes out of crawlspaces and basements). Grandpa also used driplugs in his spark plug holes to keep the cylinder walls from rusting. You can get them from Moss Motors.Dennyboy said:I searched for a while on the forum, but couldn't fine a thread on it.
What do you guys do to your cars that you store in the winter months. such as tips to keep out mice, fuel, filters, etc..?
hahahahahadream on mcss said:Just put some sta-bil in the tank, run it through, and ya should be good! And if any mice get in exhaust, its their *ss when you finally start it up and blow it out, lol.
