The best theft deter-ant, is a well kept secret! 😀 you should devise some type of hidden switch, or take a hand held rotary tool (dremell) and craft something in your car into a switch, that nobody would ever think is a switch, then hide the wires extremely well.
Idea's for hiding wires, you can paint them the same color as the surface they rest against, and glue them down. Or, if the wire runs to the ignition switch on the column do what i did, hide the wire IN the column! use a very small drill bit, and run the wire straight to the hookup on the ignition switch itself from the underside, up through the column and into the switch.
