Yep another new guy
406monte
Jan 24, 2009
57
6
50
Quantico, VA
Well, i just found out about this site from MonteCarloSS site and thought i woud get it a look at and join. I have an 84 Monte Carlo SC right now. I have had 3 previous Montes before, 2 78 montes and another 84 monte. I am a die hard Monte addict. The wife says i eat sleep and dream of my car she also calls it the other woman. I am in the USMC currently in Afghanistan for 7 months. I have been stationed at Camp Lejeune, NC for 14 years. I can't wait to get back and start on the car and get back to racing it. Here is a pic of the car. I will post some vids of the car at the track in the general section so check it out. 8)
Welcome! Your car looks awesome! I like that console too!
Thanks all, the console is out of a 99 Pontiac Gt. I got it cause i was tired of not having a cup holder for my drinks and what not. It took me about an hour and a half to install it. I think the only mods aere that it is a 4 speed shifter. What i did was installed a set screw in the 4th gear notch on the shifter to keep it from going into 4th making it a 3 speed now. I had to flatten the tunnel a little to get it to sit falt and bolt to the cover. It has 2 cup holders and two accessory plugs in it. It sits pefect for my arm and shifts nice for the track. I have my line lock hidden in the little ashtray compartment and my nitrous activator switch is in a hole on the console exposed. It is the best mod i think i have done for it i get alot if compliments on it. I have influenced a few monte guys on MonteCarloss forum to install one in their cars.
The motor is a 406 hydraulic roller motor with Trick FLow heads with 10.5 comp. All forged with a Callies Compstar 4130 Forged crank and H beam rods and Forged Mahle pistons. The block was decked, plate honed, bored, sonic checked and line bored and then balanced. I have a .558 roller cam and victor jr intake a 750 Demon carb and complete MSD ignition. The motor is built for nitrous and is completely studed top and bottom. The transmission is a 350 turbo and a 3400 stall nitrous converter, and hardened sprag and shift kit. The rear is a stock 7.5 with 3.73 gears and Auburn posi. I run a 28x12.5x15 Mickey Thompson Streeet E.T at the track. I have UMI upper adjustable control arms and UMI single adjustable lower control arms. An air bag in the right rear spring and Lakewood drag shocks on all four corners, 90/10 front and 60/40 rear, Mooso trick springs on all four corners. That is the car in a nut shell. I pull a 1.7 sixty and have had the tires off the ground on my last two runs i made before coming to Afghanistan the highlight of the build so far.
When i get back i have a 12 bolt rear and strange full spool 4.10 gears and c-clip elims and 33 spline strange axels for it with a t/a girdle. An 830 Holley dp and electric water pump manual steering box and a 250 NOS plate kit to install. Lastley an 8pt cage for it. I am hoping for low 11's on motor and 10's on the bottle. I don't think it is out of my reach with these parts when i get back. Sorry fo rthe long post i just get carried away in describing the car. 😀
406monte said:
Grand Prix
sweet, i couldnt tell. I am wanting to do a conversion from a gp to my car, seats and all. my freind has a gtp with leather, and those seats are nice too.
Good luck you will like the convenience of the console. I think it would all look good in your car. Can't wait to see the install and finished pics.
got a whole rotted out interior to replace so dont hold your breath! lol
btw, Was your car colum shift or floor shift origionally? do you have any clue if you can adapt a colum shift to the floor shift?
