I was finally able to get my monte carlo moved to the house the other day. I got a few parts I had got off ebay a while back that I never installed like a steering gear from a 83 z28. I was able to pull a steering shaft from a 92 Jeep Cherokee Laredo this swap looks straight forward except for Im going to have to notch my column shaft. Whats the easiest way to do this?
Also I got to swap over my pitman arm to the z28 box. Im going to have to wait to do that because my pitman puller got stuck on the z28 box tried pulling the z28 arm off without the gear installed in a car. Pretty much car still has the 305 thinking about getting a sbc 350 from a 93 truck for 400. Will the 4bbl gm intake go on a 93 sbc 350 efi?
Cant wait to get the shaft installed and gearbox should go great with the moog springs I put all around. Next im going to wire up a switch to work with the 700r4 the lock up. One other thing my brakes are not working properly. The front brakes keep locking up and its hard for the car to move. I replaced the brake caliper a few years back and the car sat up afterwards, I have the car jacked up and its hard to rotor the 2 front wheels if I unscrew the valve on the brake it looses the wheel and im able to roll the wheel freely.
