ok, i figured id start a build thread for my cutlass. for couple of reasons, 1 to help motivate me when i feel unmotivated
, and 2 , to document what promises to be a huge-*ss project, and finally, im sure ill need some advice from some of you guys who are more experienced with the G bodys ( yeah yeah, i know technically mines an A body ) since i grew up in a mopar household. its basically a rolling body. no interior, no motor or transmission.
it doesnt look much different than it did when i drug it home a month or so ago, but i have been doing little things to it. the genius i bought it from lost the keys to the trunk/doors between the time i bought it and the time i picked it up so we had to remove what was left of the back seat and climb through to get the trunk open, which was harder than it sounds because the trunk is where all the trim pieces and tail lights are located, along with the gas tank he removed for some reason. i also had to get the hood open, the cable was frozen, that was a treat. been kind of just cleaning it up and figuring out which way i want to go with it for sure. the guy i bought it from threw in a small block 350 and an engine stand to go along with it. after getting itt home i ran the numbers and figured out it is a 86'ish ( block says 86, heads say 87 ) 285/300 horse crate motor. i dissasembled it and everything appears to be in pretty good shape. not sure if im gonna use it for this car or not or what im gonna do with it yet. the heads are 1.94/1.50 64cc models. the block looks all stock. it also came with a polished edelbrock RPM airgap intake. so for $900. i think i did pretty good. few pics of the motor
