i am swapping a pontiac 400 into my mc ss. motor is in mounts, transmission is in mounted with crossmember. this swap is sweet. big problem i am having is, i am having no luck finding headers. please help.
I doubt they will fit, virtually all Pontiac V8 headers will fit all Pontiac V8's with the exception of the type of head port that you have ex. round port vs. "D" port heads, but it's not the problem fitting the headers on the motor, it's the problem of fitting the headers in the engine bay. The passengers side is no problem but the drivers side with the steering column is! Where is SHOTGUN>>??? he will surely chime in on this one, maybe he knows a set of headers that will fit a G body>>???fullmonte said:Ive got a 78 Monte Carlo and will be putting a Pontiac 455 in it. Guy at the racing shop is settin me up with my rear suspension and just got a ford 9 inch from quickperformance.com. My race shop guy told me GTO headers will fit in my car with that motor, maybe same for you so check it out.Hope this helps!
