Steering Column question
Hi, I am a new member with a question. Does anyone know if the turn signal assemblies can be swapped out on a G-body steering column? My reason for asking is, I have a '78 Cutlass with column shift that I am converting to floorshift. I would like to swap the column to a floorshift column, but all I seem to be able to find is '82-up floorshift columns with the windshield wiper controls on the turn signal stalk. Is it possible to put a '78-'81 turn signal assembly into a '82-up steering column? It looks like all the columns are identical from '78-'88 except for the turn signal assemblies. Also, I am aware that the '78 cars have the splined shaft, but I plan to do the Jeep Cherokee steering shaft upgrade so that's not a problem. Thanks in advance for any help.
