Just Playing
nicely done....you had to be shifting manually or is how the governor is in your transmission? I always read the nice 200 r4's would shift at 5800..
Sounds really good Randy! that a stock trans in the 442?
I let off and let it shift at 5800-6000 rpm, gov is setup to shift at 6200 which feels really good with the cam and port work, but I don't like to overdo it just playing around so I let off at each gear a bit. Not bad for a "pig" 307! :mrgreen:
Mild shift kit, and gov tweak, that's the way it was when I bought it. The people that did the engine put together a great combo.
I can't see it 🙁
If click where it says 'facebook', it should work, I just tried it.
