Scroll up to vote!
We had an outstanding year for G-body of the month this year. I would first off like to thank everyone who participated. To finish the year off strong there will be one last competition for the year between all of the winners. The car/owner with the most votes come December 25th will be crowned G-body of the Year! You get one vote, so make it count.
Pictures and Descriptions are below for each car.
Voting ends December 25th
Feel free to discuss about the rides below as well
Good Luck winners! Happy voting!
***Note*** Please be mindful of who you are actually voting for, the member's name and ballot selector is located above the picture, NOT under it. ALSO make sure you hit "submit"
The Rides:
nowukno’s 1980 wagon, January winner. (Best Wagon)
454muscle’s Grand Prix, February winner. (Best Custom)
1984 Pontiac Grand Prix "Pro Touring" Build, AKA Project RAWDOGG:
Engine: Edelbrock/Pat Musi BBC 555 EFI Crate Motor (694HP/650 ft.lbs.), March Pulleys serpentine belt system, Custom heater box housing a Vintage Air A/C system, High output alternator, Aluminum BeCool radiator, Dual electric cooling fans
transmission: TCI 4L80E Superstreetfighter+ Manual/Automatic valve body + 2500 stall lockup converter + stage 2 shift kit
Rear End: Currie Enterprises Stage II posi 9" Detroit Locker rear end + 3:89 gears
Suspension: RideTech G-Body Street Challenge Levelpro air ride kit including including upper and lower tubular control arms, strong arms, front and rear anti-sway bars, double adjustable aluminum shocks
Body: Custom body kit with shaved doors and trunk, GTO Judge spoiler, Custom fiberglass hood with 4" vented cowl "Daytona" style scoop
Interior: All black-vinyl upholstered interior, Power heated black leather bucket seats, Custom dash bezel with black powdercoat, 10 Autometer Cobalt gauges, Dakota Digital climate control with AC and heat, G-tech Pro 4" tach on top of the dash, Custom center console with iPhone base, power window switches, stainless steel cupholders, Night Rider GPS unit, hidden switches, B&M 4 speed Megashifter, Premier head unit + 4 x MB Quart 216 component speakers powered by Alpine and 2 Rockford Fosgate T2 10" subwoofers powered by RF power amp, power windows, power side/door mirrors
Shoes: Eagle Alloy 028 polished aluminum 15x10 wheels in the back, 16x7 up front, 4 wheel disc brakes (cross-drilled and slotted rotors)
Exhaust: custom made ceramic powder-coated headers, 3" full mandrel bent pipes, 2 high flow Magnaflow cats, 3" H-pipe, 2 Flowmaster Super 40 mufflers, 2 x 24" x 6" chrome 'sewer pipe' tail pipes
Backshots:
Videos:
[youtube]QZFZwsTWaj8[/youtube]
[youtube]0snLyC1p2kE[/youtube]
[youtube]ee4jSFLjjWA[/youtube]
Carfreak07's Monte Carlo, February winner. (Best Custom)
1987 Monte carlo LS with LS1 and 6spd Camaro Dash, pw, pl, keyleaa entry, radio controls on the steering wheel, heat, AC, it also has a 12 bolt in it with f body disc brakes and a 410 gear.
Oldsmoletick’s 81 malibu classic, March winner. (Best Four Door)
I purchased it 11 years ago (my first ride), originally had a 229 V6, been through a couple engines, transmissions, and rear ends since, lol. Car was involved in a deer incident back in 02, which did a bit of damage to the roof (still isn't right 😳 ). It sat for 2 years, while I rounded up parts to fix it, then spent 04-spring 08 in primer, Painted it over the summer (came out kinda crappy though) back to the factory green.
The current engine:
77 olds 350 shortblock rebuilt with an rv type cam, stock rebuild on 1970 heads ("6") samll valve, edlebrock carb (temporary) and intake, hedman headers, stock ignition currently, had msd but the box crapped out :x .
The current transmission:
Chevy TH350 longtail, I built it for a friend of mine, B&M transpack, 2100 stall, homemade BOP adapter, nothing special, he owed me money, and I needed a transmission, so I took it on trade, lol.
8.5 Rear with 3.73's round up the driveline.
Wheels are 15x7 Olds SSIII's that I picked up for cheap on the side of the road.
Suspension is all stock, minus the F41 rear bar that I added, along with the frame/body braces, and poly body mounts.
Interior is an abombination :lol: ;
Buick Regal Dash (malibu dash was another victim of the deer hit), olds acheiva buckets mounted to g body rails, AMC/Jeep steering wheel, Olds/Hurst quarter stick combination shifter (I was pickled and bored when I came up with the idea ).
speedkills80’s 1980 Malibu Classic, April winner. (Best ’78-’80)
396 4 speed 12 bolt posi 3:31. Roller cam, lifters, and rocker arms. M - 21 with a lakewood bellhousing. A/C delete, factory bucket seats without console.
kuruption’s 81 Malibu, May winner. (Best ’81-’86)
Project car, factory 3 speed and v6 229
Here is the link to his build thread from day one:
http://www.gbodyforum.com/viewtopic.php ... t=tha+runt
outinfront442’s 87 Cutlass 442, June winner. (Best ’87-’88)
1987 442 with a 355sbc with a 150 shot nos. It has a built 200r4 has tv, full audio system 2 amps extra battery two 12s and gretting ready to fiberglass the whole trunk. putting drop spindles and supercharger soon to come!
Carlola’s Monte Carlo, July winner. (Best Project in Progress)
Fully boxed frame
13" c5 front brakes w/blazer spindles, 12" wilwood rear
355 sbc / 700r4
-aluminum heads
-forged pistons
-edelbrock airgap intake
12 bolt
-shortened to g-body width and brackets
- custom dutchman axles
-3.42 gear ratio
jrm81bu’s Malibu, August winner. (Best brand faithful)
350 sbc
Edelbrock Performer RPM heads
Weind 142ci Supercharger
BowtieOverdrives 700r4
3.73 posi 7.5 rear for now
Coy's Black Chrome C5's
Always a work in process and beat on relentlessly!
Build thread: viewtopic.php?f=25&t=17740
Mike P’s 83 El Camino, September winner. (Best Truck)
I decided to it would make a good home for the 500 CI Cadillac engine I’d been saving for a project. The project kind of ballooned, when I decided to change the front end and doors for a set from a 78 Monte Carlo.
In the process I built a 9” rear end for it, installed a TH400 and added a Monte Carlo SS interior and gauges. The majority of work was done in my garage. I pretty much documented the build in these threads.
viewtopic.php?f=41&t=25429
viewtopic.php?f=13&t=25458
viewtopic.php?f=14&t=25389
hurstolds6’s 84 Hurst/Olds, October winner.
"The Modern 1984 Hurst/Olds".
The work that has been done so far:
Full Suspension and Disc Brake Conversion
Dick Miller Racing Custom Oldsmobile 496 Engine w/Bulldog Heads
Freddy Brown Custom Manual Valve Body transmission with Electric Overdrive, Line Lock, Trans Brake
Moser 12 Bolt Rear with 3.73 gears, 35 Spline, WaveTrak Posi
Full Interior
Custom BOZE Wheels (Slicks on the factory wheels for the killer sleeper at the strip!)
3inch Dual Exhaust with X Pipe and Flowmaster Super 44 Mufflers
JBreu’s 84 Monte Carlo, December winner. (Best Monte Carlo)
I bought my '84 Monte four years ago as an E-Bay find from Virginia for $2100.00 It had a tired old 305 sbc with 200k on the clock with bench seats....When I bought it I planned on making it a street rod..It now has a 388 Stroker motor with a 700r4 transmission, 3200 PTC converter with a '69 Chevelle 12 bolt rear with 4.10 gears..Ran a best of 12.47 @109 mph a few months ago. I recently had it re-painted with the stock color and added a goodmark 2" cowl hood and also a SS spoiler on the rear....Here's a link to the paint job: http://www.gbodyforum.com/viewtopic.php?f=3&t=27233
Good Luck again and thank you to those who have voted.
Thanks
-Mike
Scroll up to vote!
The Rides:
Backshots:
Videos:
The current engine:
Fully boxed frame
355 sbc / 700r4
-aluminum heads
-forged pistons
12 bolt
-3.42 gear ratio
350 sbc
Full Interior
Thanks
-Mike
