Starting this morning my left turn signal no longer blinks. The light comes on, but there's no ticking sound, and it doesn't shut off when the wheel returns to center. The right turn signal works fine. Is it a bad bulb or something more sinister?
first check your bulbs, if they work then it's most likely a ground...best thing to do then is manualy ground your pigtail until your problem goes away (on that side thats not working)
Thanks for your help, everyone. It ended up being a flasher unit. I was able to replace the burnt-out footwell light bulb while I was in there, so it's all good now.
