starting my 1st 455 OLDS build thread
dr78442
734
914
massapequa park NY
I finally got around to start assembling my 455. So I figured I would start a build thread I hope to have the engine in the Olds by the end of the winter and have the car running by spring to make the 2012 season . I will update this thread as I make progess on the build.
This is when I first the 455 back from S&S speed
Priming the oiling system
Re: starting my 1st build thread
nice what pistons heads and cam did you go with? what you lookin at for power?
Thanks positive feedback . Some details about the engine are 72 455 from a Delta 88. The block is .30 with speed pro forged pistons 10.1.1.The rotating assembly has been balanced. I am using a Mondello roller cam with the following specs duration 280/274 Lift .523/.512 with lobe seperation of 114. A set of edelbrock heads and roller rockers from Mondello as well. I will be using the fuel injection from my 502. I hope to get 480 -500 horse out of this combo.
455 looks good. What kind of injection, specifically the intake, setup are you using?
Thanks .. I am using crossings intake and ramjet harness and module all GM sensors
sweet.. cant wait to hear dat bad boy in action... great job keep us updated.. :lol:
wow that looks awesome. whered you get your headers from?
