rear control arm bolts
mikester
2,934
3,741
Small town NY
FYI, Belmetric sells grade 10 hardened conical locknuts for $0.71 and hardened flat AN style washers for $0.28. You would still have to measure the length of the bolts and price them out.
L05edSS
235
128
I have UMI control arms on my wagon but I wouldnt use the UMI bolt kit. They say the bolts are 10.9 but are the washers ? Also it comes with nylock lock nuts. Something I would NEVER use on suspensions. Too easy to take off compared to prevailing torque lock nuts. Also I doubt if nylocks are grade 10.9. They gotta match as far as hardness. I would use a nylock on a snowblower or lawnmower. Not a car. Just sayin. But its your car.
interesting input, i still got time to reconsider.
SS_Malibu
1,183
2,090
Mesa, AZ
If it were me, I would just go to ACE hardware and get grade 8 everything and be done with it, but I'm not concerned with it being stock.
L05edSS
235
128
can you explain why nylocks been a issue for you, cuz i'm also lookin at a set for my front lower control arms from SSM sold on amazon. you broke my brain with this revelation. "
1978-1988 GM G-Body Front Lower Lower Control Arm Hardware Kit​
they $15 nylocks. i'm in a wheelchair so doing work on my own car is 0, pickin parts for someone else to install i can do. this why i won't go with tubular front & rear control arms cuz they need greasin' + i dont have but 210 hp 300 tq. before broke my neck @16 i was a backyard bike & gokart hack wrencher so that skill never left my head. lol
i'll never pretend to know more than i do & always willing to learn.
mikester
2,934
3,741
Small town NY
Easy explanation. Nylock nuts go on and come off without much effort. Prevailing torque lock nuts are the exact opposite. They go on hard and come off the same way. Im pretty sure thats why car companies use them on suspensions. Theyre also hardened like the factory bolts. Makes no sense to use a hardened bolt and soft washers and nuts.
A friend of mine had a 71 Chevelle built by a local guy. Pro touring. Big block. Real nice build. It took well over three years to have it done. Big money. The first time he took it to a show in NJ he lost a bolt n the suspension as he was going over the Verrazzano bridge and had to have it towed home. Can you guess why he lost the bolt ?
Dont get me wrong, I know people that use them all the time. I also know people that put their cars together with grade 3 bolts from their local hardware stores. Everyone has their own opinion on whats good and whats bad. My opinion ? Its not much more money to have the proper grade and proper design hardware. Ive got a lot of money tied up in both of my cars. I'd hate to have something break because of a few cents saved buying the wrong stuff. Factory bolts are metric and grade 10.9. Pretty sure prevailing torque nuts are grade 10.
Its your car. Use what youre comfortable with.
69hurstolds
8,259
17,785
Simple fix for those nylock nuts with at least two ways. Probably more but these work. (Best way is to not use them on suspensions.)
1) Drill a cross hole in the end of the bolt and insert cotter pin. More as a safety last ditch. Of course regular inspections would be required.
2) Most preferred way is to hire this particular welder for tack welding. I'm sure she could get my nuts hot anytime she likes. :)
Nuts are cheap.
M12x1.75
Prevailing Torque Nuts, aka Stover "cone" nuts. They lock based on slight deformation of the threads. Deeper you go, the tougher they bite. Once installed, they're not going anywhere.
  • Love
Reactions: 5 users
L05edSS
235
128
Its your car. Use what youre comfortable with.https://st.hotrod.com/uploads/sites/21/2017/08/g-machine-11.jpg
ok you changed my mind. i used nylocks in many other situations no issues and never thought would be different in suspensions. thanks and now i'll go back on the hunt for the correct 1s.
mikester
2,934
3,741
Small town NY
I bought all the hardware for my wagon from belmetric. That was for the front and rear suspension. I also bought the stuff for the front end of my coupe from them. When I was doing the rear suspension in the coupe I didnt know about belmetric so I hunted everywhere for hardened metric nuts and bolts. I wound up getting most of the stuff from the local John Deere dealer. They had grade 10.9 cone flange nuts. They worked just as well.
You can also get metric stuff here. https://boltdepot.com/Product-Details?product=8806. These nuts are only $.46.
Im pretty sure everything I bought from bel was yellow cad plated. Nuts, bolts and narrow washers.
