I bought one Cragar Soft 8, a 17", 8" wide, 4.5" backspace to use for test fitment. I know a few members use these, and have seen info in the past about using a half inch hub centric spacer for the front wheels due to clearance. I test fitted the wheel on the front, and definitely see the need to use a hub centric spacer, as it hit the upper A arm at full lock, and the hub was a bit smaller than the wheel opening.
Off the top of your heads, can you recommend the exact spacer I need? The website lists the center bore diameter of the wheel as being 3.300 inches.
http://www.summitracing.com/parts/crr-3998834/overview/
__________________
__________________
