I have a 1978 factory 4 speed,red buckets console,PW,PDL,Tilt,A/C,Tach & gauges,removable grant #749 steering wheel
461 BBC,8.5 3:42 buick rear with aluminum cover,large sway bars,aftermarket front & rear upper & lower arms,
Moog 1" drop springs,quick ratio steering box & shaft,rear trailing arm braces,front upper & lower braces,centerforce clutch,aluminum radiator,engine has not even been fired yet,high perf factory heads,polished RPM manifold,holley 850,milodon large pan,GM small high torque starter,Hooker 2241 headers,every part on the car is detailed,painted powder coated etc. has choo choo nose with single composite headlights with aftermarket headlight buckets for the choo choo nose,rear tucked fiberglass bumper,trunk is detailed painted red over bed liner spray, battery is located in spare tire well,bottom of trunk and hood painted red,all body work prof.done,all panels lined up and in black DP90 epoxy primer,
has new Goodyear Nascar #1 235x60x15 front,255x60x15 rear with 8" black daytona Nascar style wheels,been in the garage or carport most of its life, do not need to sell, but cannot seem to make time for it,would like to se it go to good home
have no idea what I have spent on it ,will sell for 4500.00 firm,that's a steal,in SE OK 74735 580-743-0297 Thanks Mike
