BUILD THREAD 1982 Malibu Wa-GOON 6.2/4L80e/8.5
Misfitmike63
Apr 11, 2023
73
326
53
Was thinking of making a new shifter linkage, but then figured I’d just modify the stock one. Drilled part of a coupling nut out, slid it over the end and welded it on. (Was originally going to thread the stock rod) Now I just need the new linkage to show up so I can use parts from it!
Reactions: 7 users
64nailhead
Goat Herder
Dec 1, 2014
5,718
12,241
Upstate NY
VSS… didn’t think I needed it with the Holley kit… I’ll cross that bridge when I get to wiring😂
I missed this on the 1st read through. So you're running a FiTech intake and a Holley Term Max or Dominator?
Great build, very well done.
Misfitmike63
Apr 11, 2023
73
326
53
I forgot to say, yes it’s the FiTech top end kit with the Holley Terminator X Max kit.
After I get the transmission linkage done, all I have left is the wiring, exhaust, and tuning.
Once that is done, I can start my 14” & 12” brake swap
64nailhead
Goat Herder
Dec 1, 2014
5,718
12,241
Upstate NY
So the plan with the speedometer drive tailhshaft housing is to use the factory Speedometer, eh?
Something that is neat with the newest software is the traction control. A Blazer wheel bearing or some type of ABS setup on one of the front wheel's will give you traction control.
Misfitmike63
Apr 11, 2023
73
326
53
Got a little done to the linkage. The metric nut to hold on the selector arm was missing, so I need to wait for that.
Misfitmike63
Apr 11, 2023
73
326
53
Hooked up my column shift to the 4L80e using parts from a generic linkage kit and some parts from the hardware store. I can get P/R/N/D with ease. Getting into 3/2/1 is difficult since the lever goes beyond the 6 o’clock position. If I did a little more modifications, I think I could get all of them.
This is in D.
Anyone happen to have a metric one of these bolts? I got 2 standard ones in my kit
