MONTE CARLO 1987 MC SS RIM BOLT SPECS
The Last Don
106
22
Seattle, WA
Hello, I am looking to order some rims online and am not sure of the wheel size and bolt specs. I am looking at 18x8”/5x4.75 - will these fit my MC?
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
12,177
9,796
Gainesville, Fl
Theoretically, they'll bolt on, but will they clear... depending on what size tires you use.
Do you have all the specs...backspace, offset, etc.?
The Last Don
106
22
Seattle, WA
The Last Don
106
22
Seattle, WA
4" BS would work better in back. 4.5" will work fine in front. What size tire will you be running?
To be honest I dont know what would be best in this situation. Suggestions? I want to move away from the 22 inch rims - want to get more rubber for a smoother ride.
UNGN
3,048
3,267
Southlake, TX
255/40 18's will be close to stock height @ 26" And should fit all around with minimal mods and maybe a small spacer in back.
If you had a 9" rim in back with a 4.5" BS, a 275/40 would be 27" tall and would be about the largest you'd want to go without mods
  • Informative
The Last Don
106
22
Seattle, WA
So what would be the ideal setup? I dont know a whole lot. I am learning, soaking up as much knowledge as I can. Reading a little and watching some videos has me concerned about not using the same rim/tire specs as the stock setup. But, I like these iroc rims! The current tire and rim size is 245/30ZR22 92W - they look damn nice but the ride is so shitty... There is no spacer in the front but the rear, it has a 1.25 inch spacer. Front and rear tires are wide - I measured the tire and it seems to be 10 inches wide - like the way that looks - but when I turn it all the way it rubs...
