OK... now as I said after waiting for the perfect saturday the 400sb came out on saturday, roughly 4 hours without cutting too much of anything besides the sh*t that i felt to be completely useless like power steering lines.... today at work it was relatively slow and so i got the block down to just crank and pistons and everything was pretty clean, no coolant leaks, little bit of sludge built up in the corners but its to be expected anyways... the important question... i can pretty much make up my own mind on everything else but this has way to many variables.... pistons, now iv asked a little about this before I think and unlike my audi where theres really only 1set I can buy, were talking small blocks so there's billions and the only way to narrow them down is by how much over I want to buy and the top style... even though questions still linger about the efficiency of different styles of pistons in different conditions, I would prefer to go with flat tops for the soul purpose that its in the lead for most of the discussion, but anyways... I don't really want to make the cylinder walls any tighter but I figured maybe I should go with a piston that's like 4.130 or 4.145 or something in between but also I should mention that I do not want to spend much more than 300-400 bucks... I also read why the kbs have a bad rep and I'm not really concerned with that so all I want to know is in your own wisdom great forum, for under 400 bucks what set of pistons would you recommend that are forged, flat top, and closer to 4.125 bore
now if anything I said is nonsensical correct me but thanks for any input
