81 CABALLERO 3.8L V6
PAPERGATOR$
13
My 81 caballero 3.8l V6 has these wires unhooked. The ignition wire from the fuse box and 2 red looking wires. I traced the 2 wires and one was going to horns and the other one was routed to the battery, but it’s not hooked up on either side. Where do I put the ignition wire from the fuse box and the other thick red wire. Thank you.
9,208
15,498
That's all add on wire. The end in the fuse box needs to be traced to find the end & see if it's powering anything. If not, pull it cause that's an energized wire while the the key is on. The other hangers just look like a hazard that could catch your feet.
