I did get a set of pulleys FAST from a Buick brother named Del - thanks Deadmanscurve!
I replaced the 1978 stamped steel waterneck with an Aluminum cast unit sanded flat, and used a new gasket with some sealant on it....no more seepage. It helped that I removed a bit or two of old gasket from the manifold that I missed last time.....
I am held up from starting the car while I wait for the appropriate pickup coil to arrive So I can get the HEI sparking.
The engine does turn over and will be up and running as soon as I get that pickup coil. I had to special order it from the factory.
By the way - the 5 pin Ignition module for this setup was Expensive! bah its only money, cant take it with me, right?
The vacuum advance can is busted on my distributor, will have to look for another or a replacement unit....its not available at the local carquest.
