Thank you.
I would think just painting the inside gloss white would get the job done when/if using LED's. The older style bulbs generate enough heat that the plating is needed & paint would discolor.
Nice solution on the SS option though.
I agree with gloss white as a reflector. It can reflect up to 80+% of light. I just wasn't sure how it would look behind the tint if that makes sense.
The SS i used is most likely a higher percentage of reflection as its a #7 or #8 grade polished surface. And one and a half square feet only cost me $17. I had the night shade from previous project. The leds inside the housing are very bright but can't really convey in my pics.
Here's some of the process not that it's rocket science. I like little projects like this. Stupid simple stuff keeps me entertained.
Templates made and cut SS and this is satin side for reference
Originally tried using a 2 part epoxy glue to secure the two but wasn't successful. So rivets and small bolts were used. Tops, bottoms and sides bent and trimmed.
