94 Blazer 2dr 5.3 Twin Turbo (Tyclone)
mclellan83
4,375
9,837
Pgh, PA
The major holdup had been waiting to get the stuff to be able to weld the flanges on to the headers after cutting them down, all for them to be cast and not stainless so the welding would just crack. So now ordering another set of headers that are already shortened, wish I had seen them this way when I first got the headers. Could have saved me a ton of time, but par for the course
mclellan83
4,375
9,837
Pgh, PA
And another swing and a miss...... these headers don't fit on either side really correctly. So now I guess back to trying to get some stainless flanges and hope I can get them to weld up
mclellan83
4,375
9,837
Pgh, PA
Well more good news/ bad news, my buddy at the bike shop was able to get the original headers to weld up with the flanges so able to start test fitting but they also will pose some issues I assume. Also, my buddy helping me with the build took a crack at the tail lights since I think cutting is the best way to open them he wanted to try heating a prying them. I trust his judgement more than mine, so he was able to get them apart and has a better plan for the next time but another casualty
5,753
12,335
Shockingly a by in part doesn’t fit properly when bolted on!
It looks like they could be modified relatively easily. If you plan to wrap them (recommended), then extend the straight sections off from the flange.
mclellan83
4,375
9,837
Pgh, PA
Well that is part of the problem, the first set were too long when I got them and my buddy had suggested trimming back to the collector. Now that I have it that way, he is saying we need it close to what it was. So we will see how it looks once I get the modified ones in place, I am avoiding the wrapping and probably just going to coat all the exhaust since we can do that in house
mclellan83
4,375
9,837
Pgh, PA
Some test fitting and moving stuff around
mclellan83
4,375
9,837
Pgh, PA
Ordered these to hopefully get some more room and cut fabbing time down, will have to cut the t4 side off to put 3" v bands since he says he will be making them eventually but not anytime soon
mclellan83
4,375
9,837
Pgh, PA
Cut off the T4 to mount up the V-band so that it pulls it back from the core support, first one went very slow but pretty smooth. Second one I think my buddy was trying to cut too quick because it ended up jacking up the blade and stopping progress. But figure if I have one I can use it on both sides to mock up for the time being until the I get the second one wrapped up
mclellan83
4,375
9,837
Pgh, PA
Believe this is basically where the drivers side turbo is going to live, gonna end up clocking it for a smoother run to the intercooler, wish I could get them both to mount and look this way but not gonna match in the least. Maybe version 2.0 will get mirrored turbos
mclellan83
4,375
9,837
Pgh, PA
Got the other side mocked up, not liking that it looks more and more like I won't be running a hood or will be having some large cuts to them. At the moment I don't want to drop the couple thousand dollars to get some headers that would make everything fit better. Also worked on the fuel leak, ended up replacing the fitting
