So my 95 Blazer had a coolant leak coming for near the lower corner on the driver side from inside the fins. Now this wasnt a constant leak. It would Leak during warm-up but once the truck reached its normal operating temperature it would stop leaking. I was having NO problems overheating gauge has been working fine, its shows cold on initial start and warms up in a timely manner. So I changed the radiator flushed the system and refilled her up with new 50-50.
Here it is about a month into the new radiator and WTF same side where coolant goes out of the radiaator is leaking, a bit higher in the radiator fins but same area. There is nothing comming into contact with the radiator to cause the damage. I wondering what im missing.
I was thinking maybe a stuck thermostat that maybe built up pressure in the radiator but i should be overheating if that was the case, and i checked the passage to the overfloe and it is clear.
ANY IDEAS??? My warranty is still good on my radiator but i dont want to see this problem again.
