Bad converter symptoms.
jacobdavis1979
700
14
Hey guys whats up? I was just wondering if someone could help diagnose my problem. Im running a th350 behind a 5.3 LS. The cam i chose was the edelbrock 2215 and i was recommended to use 2700-3000 stall with that set up from a few different companies. And thats exactly what im running. This trans functioned perfect behind a built 350 and the 5.3 is running amazingly so its not a motor issue. Basically what is happening it will cruise down the road perfect. Easing into it from a stop works perfectly. So just being easy on it you would swear there is nothing wrong with it. Until you hammer down on the gas pedal. The 5.3 revs up and screams like a drag car going down the drag strip but the whole car is barley moving. It doesnt feel like the trans is slipping if feels almost as if i was chained to something really heavy or if the brakes were applied it actually picks up speed faster at half throttle then it does at full throttle. Its hard to explain i hope someone understands.
This was a brand new converter and ive never had one go bad but its the only thing i can come up with. Its the only thing on the whole car i changed from the 350 to the 5.3. Trans untouched the rear untouched and it was all in working order before. Any help is appreciated
DRIVEN
8,094
14,606
*CENSORED*
If it acts the same in any gear, than I would say it sounds like a bad converter.
jacobdavis1979
700
14
As far as i know it does. Ive been to afraid to drive it i dont wanna burn up the trans
truracer20
492
31
western PA
Are you sure it went into the transmission all the way?
jacobdavis1979
700
14
Haha nope. I was gun shy about that one when i put it in. Ive dropped in converters before but this one was alittle bit of a pain. But i played it off as my paranoia. Im also thinking its not getting fluid in it somehow. It only held like half a quart of fluid. Every other one ive done held at least a full bottle and still be empty.
jacobdavis1979
700
14
Im pretty for sure this is the issue just with the bad weather and all i havent been able to swap it out to fix it. I got people so confused on this one because the motor runs perfect. The trans shifts perfect. It cruises perfect. Idles around in drive perfect. Just when you hit full throttle the motor revs up and screams like the power is there but its as if the brakes were applied
jacobdavis1979
700
14
No its dished it only goes on one way.
But somthing is definitely going on for sure now. If I hold the brakes and push the gas pedal down it will brake stall up to 5000 rpm. Its only a 3000 stall
